clear macsec counters
clear macsec counters {ports [port_list]}
Description
Clears counters for MAC Security (MACsec) encryption and authentication.
Syntax Description
ports Specifies port to configure.
port_list Lists ports to clear MACsec counters on.
Default
Counters for all MACsec ports are cleared unless you choose specific MACsec ports.
Usage Guidelines
This command clears the 4 packet/octet values of the show macsec ports port-list usage command, as well as all the statistics shown under the heading “SecY Interface Statistics” of the show macsec ports port-list detail command.
Additionally, all MACsec port statistics are cleared by the clear counters ports {port_list | all} command.
The following example clears all MACsec counters on port 44:
# clear macsec counters ports 44
This command was first available in ExtremeXOS 30.1.
Platform Availability
This command is available on the following platforms.
The MACsec feature requires the installation of the MAC Security feature pack license.
Platform Ports
ExtremeSwitching 5320 All ports of all models, except 5320-24T-4X-XT, and except stacking ports.
ExtremeSwitching 5420 All ports of all models except stacking ports.
ExtremeSwitching 5520 All ports, except 5520-VIM-4X and 5520-24X 10G ports
ExtremeSwitching 5720 All ports of all models except stacking ports.
Extreme 7520-48YE-8CE All front-panel ports.
